Question 4th monitor not working on 3060ti
slash2378
11
Hi
If I try to connect a 4th monitor to my 3060ti it doesn't work. It has 3 DP and 1 HDMI, if I use any of the 3 ports everything works if I add a 4th on a DP or the HDMI it doesnt receive signal
I have a 144hz, 2x 75hz, a 60hz
Thanks
Hi
Thanks
that is a lot of monitor to refesh.
plug the 144Hz monitor in first then set a profile to run at 60hz, then add the others all at 60hz and see if it works. if it does then try to kick up the monitor profiles to higher refresh speeds
https://www.quora.com/Can-you-run-a-144Hz-monitor-at-60Hz
