4th monitor not working, sapphire dual-x r9 280
paddy west
6
Hi everyone,
I am looking for help, as I've been making a basic flight simulator and can do all the making etc but can not get a 4th vga monitor to work, it will detect it but then says you must save previous settings before applying.
Its got 2 dvi ports a hdmi and a display port, im using a dvi to vga adapter.
I've also tried using a pluggable usb to vga connection but this does not work on my pc?
any help would be greatly appreciated,
paddy.
Is it an active adapter? We need lots more details.
This is my setup at home. Powered by a 7950/280, I'm using two active mDP to DVI adapters for the surrounds. Straight DVI for the center monitor, and my TV is hooked up with a 25' HDMI cable as well. (not in the picture though.) If you can only get three to work I suspect your DP to DVI adapter isn't an active one.
so i am using 2 aoc 21.5" monitors with dp and hdmi inputs, one actually using dp (from the graphics card dp) the other hdmi (from a dvi port in a direct cable) and the 3rd ( samsung 21") using cdmi to hdmi)
