5.1 setup Rear Speakers playing as if they were Front
KDCheapCheap
I have the Logitech z506 5.1 speakers, all of the connection are correct however when doing the sound test in Realtek or xPro, the Rear Speakers play from the front and vice versa. Any fix?
Check the options in the audio controls for the sound card or you just have the rear speakers plugged into the front speaker ports. And if the front to rear sounds are reversed but you have the in the right ports, just plug them into the "wrong" ports and it should reverse to sounding normal.
KDCheapCheap
Thanks for the reply, I've looked into the settings of realtek and x-Pro and I can't find anything that reverses them. And as for the ports I can safely say their in the correct ports however I can't just simply switch them round as the front right is plugged in via VGA where as the others are all jacks.
What do you mean plugged in via VGA? VGA ports don't have an audio option. I think your issue is that you don't have things plugged into the right areas for the system to function properly. Make sure you read the instructions that came with the speakers.
