As of latest patch Edge processes are running in bckground at startup despite it being turned off in Privacy>background apps via Settings
I should mention this is 2018—KB4103721 (OS Build 17134.48) and specifically what IS open
Microsoft edge manager
chakra jit compiler
Runtime_broker
Browser_broker
user interface service
background tab pool
These are all found under the Edge tab upon startup. Does anyone know how to disable them ? there was no problem with previous window 10 versions, and they seem to slow down my machine when attempting to play games. I can CTRL+alt+del to manually end the process but it seems silly that i cant find the setting to disable these unwanted processes from starting automatically. Yes all brackground apps are disabled under privacy, and i have tried repairing and reseting edge to no avail.
All three PC's in our house have the the same problem after the update, Anyone have any idea?
chakra jit compiler
Runtime_broker
Browser_broker
background tab pool
