5 Beeps when lapotop boots up. Changed CMOS battery but still beeps 5 times.
rhushiarnd
9
Hi,
When I turned on my laptop it started continous 5 beeps. Which usually means CMOS battery failure. So I replaced CMOS battery with a new one. But the problem still exists.
But sometimes laptop boots normally.
I noticed one thing that sometimes no beep when power adapater is connected. But sometime it doesn't. And there is no LED when power adapter is connected.
Beeps at start up...
8 Beeps on startup means the LCD on system has failed (or is failing). 6 on startup would mean it is your GPU.
You might want to try running a LCD Test, as well as a Pre-boot System Assessment.
So now you are probably thinking "How to run these tests?" :)
First, turn off your laptop.
For the LCD Test...
1. Hold down the 'D' key and then turn on your laptop
2. Keep holding down 'D' and you should see color bars on your LCD.
Again, turn off the laptop...
For the Pre-boot System Assessment...
1. Hit the 'F12' key immediately after turning on your system.
2. From the options displayed, choose 'Diagnostics' .
This will tell you if there are any errors that you need to address/fix.
Other beep codes....
NOTE: Due to the fact that different manufacturers with this BIOS have different codes, the beep codes may vary.
Below are the AMI BIOS Beep codes that can occur.
1 short - DRAM refresh failure
2 short - Parity circuit failure
3 short - Base 64K RAM failure
4 short - System timer failure
5 short - Process failure
6 short - Keyboard controller Gate A20 error
7 short - Virtual mode exception error
8 short - Display memory Read/Write test failure
9 short - ROM BIOS checksum failure
10 short - CMOS shutdown Read/Write error
11 short - Cache Memory error
1 long, 3 short - Conventional/Extended memory failure
1 long, 8 short - Display/Retrace test failed
two-tone siren - Low CPU Fan speed, Voltage Level issue
Below are Award BIOS Beep codes that can occur.
1 long, 2 short - Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
1 long, 3 short - Video card not detected (reseat video card) or bad video card
Beeps repeating endlessly - RAM problem.
Repeated high frequency beeps while PC is running - Overheating processor (CPU).
Repeated beeps alternating high & low frequency - Issue with the processor (CPU), possibly damaged.
Dell beep codes
1 beep - BIOS ROM corruption or failure
2 beeps - Memory (RAM) not detected
3 beeps - Motherboard failure
4 beeps - Memory (RAM) failure
5 beeps - CMOS Battery failure
6 beeps - Video card failure
7 beeps - Bad processor (CPU)
Below are general IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary.
No Beeps - No Power, Loose Card, or Short.
1 Short Beep - Normal POST, computer is ok.
2 Short Beep - POST error, review screen for error code.
Continuous Beep - No Power, Loose Card, or Short.
Repeating Short Beep - No Power, Loose Card, or Short.
1 Long and 1 Short Beep - Motherboard issue.
1 Long and 2 Short Beeps - Video (Mono/CGA Display Circuitry) issue.
1 Long and 3 Short Beeps. - Video (EGA) Display Circuitry.
3 Long Beeps - Keyboard or Keyboard card error.
1 Beep, Blank or Incorrect Display - Video Display Circuitry.
I have the same issue as the OP. I replaced the CMOS battery, but still here 5 beeps. I am able to turn on the laptop and access all files, however the computer no longer detects wi-fi networks so I cannot access the internet. Do you think the 5 beeps could also indicate an issue with the WLAN card?
