D dadalka Reputable Nov 30, 2021 82 5 4,535 May 17, 2024 #1 I want to replace my cooling fans any recommendations on quiet ones that runs about 2000rpm.
Eximo Titan Ambassador May 27, 2010 28,408 5,782 144,340 May 17, 2024 #2 Depends on how many you want, their size, and your total budget. You can spend $10 a fan or up to $30 a fan for reasonable ones.
D dadalka Reputable Nov 30, 2021 82 5 4,535 May 17, 2024 #3 I will need six total. 120mm x 120mm x 25mm. Price is not a problem. The one I have installed are rather noisey.
Eximo Titan Ambassador May 27, 2010 28,408 5,782 144,340 May 17, 2024 #4 On the cheaper side: https://pcpartpicker.com/product/by...20-mm-fans-3-pack-ph-f120m25_drgb_pwm_bk01_3p And expensive: https://pcpartpicker.com/product/dN...mium-581-cfm-120-mm-fans-3-pack-co-9050113-ww https://pcpartpicker.com/product/FC...w-62-cfm-120-mm-fans-3-pack-mfx-b2dn-183pa-r1 https://pcpartpicker.com/product/WN...nity-613-cfm-120-mm-fans-3-pack-uf-slin120-3b
D dadalka Reputable Nov 30, 2021 82 5 4,535 May 18, 2024 #5 What I'm running know are Corsair C)-90500082-WW three pins and 5 volts
