Hi, i was about to purchase a gigabyte nvida geforce gtx 660 but it needs 450 watt power supply but i have got 500 watt and i wondered if it stills works.
Also it uses a 6 pin connector and i want to know where do you plug that into the motherboard.
My questions about the graphic card
1. Can i run adobe cs6 smooth on this graphic card and will it work on intel hd graphics 4000
2. Which games can i play?
My pc spec:
Intel i7 3.5 quad core processor
16gb ram
1tb hard drive
Windows 7 64bit
Thanks
My pc spec:
16gb ram
1tb hard drive
Windows 7 64bit
Thanks
