It can only do that over DP so if the monitor doesn't have DP then he is SOL with that current card.The Quadro can't do it?
K620's can do 4096x2160 @ 60 Hz, should be plenty of bandwidth to support 5120x1440 ..... I would've thought?
As far as I can tell there are only 4 monitors on the market with that resolution, and they all have DP.It can only do that over DP so if the monitor doesn't have DP then he is SOL with that current card.
K620 3840x2160 @ 60 Hz with 30-bit color
Displayport 1.2 is capable of 17.26 Gbps. Uncompressed 10 bit 5120x1440 @ 60 Hz only requires ~13.9 Gbps.K620 3840x2160 @ 60 Hz with 30-bit color
How much are you paying for a 1050 ti you can get far better amd cards for less usuallyThanks guys plumped for a gtx 1050ti goes well over the size I need thanks again. Its so confusing.
I'm not sure of rx 570 prices in the uk, but that is not that bad of a deal if it is new. In the u.s. market the rx 570 beats out the 1050ti in scenario£100 with 12 months warranty
Cheapest 570 runs 125 QuidI'm not sure of rx 570 prices in the uk, but that is not that bad of a deal if it is new. In the u.s. market the rx 570 beats out the 1050ti in scenario
Its refurbished I see the rx beats it in just about every bench mark but as I said I want it for productivity not gaming so cuda cores are more important with the software I use. Wish I could have afforded a better card but this will do for now spent all my money on the monitor.I'm not sure of rx 570 prices in the uk, but that is not that bad of a deal if it is new. In the u.s. market the rx 570 beats out the 1050ti in scenario
The 1050 ti is a perfectly good card, in fact i'm using one right now. The rx 570 is better price to performance is all I was saying.Its refurbished I see the rx beats it in just about every bench mark but as I said I want it for productivity not gaming so cuda cores are more important with the software I use. Wish I could have afforded a better card but this will do for now spent all my money on the monitor.
