5200fx..how to speed up
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
hi i am new to overclocking and wish to speed up my 5200fx, how do i do this
sim
"sim" <tjohnson2004uk@tiscali.co.uk> wrote in message
news:407ecc21$1_2@mk-nntp-2.news.uk.tiscali.com...
this
> sim
I'm using coolbits. I can get my 5200 Ultra almost to a 5600 Ultra.
bluestringer
this
The only FX5200 type that's of any value whatsoever is the 128bit memory
version.....and 9 of every 10 of these cards are the 64bit version. You can
overclock them, but you still wind up with GeForce2 GTS level performance.
The 128bit version will perform better....like Geforce3 Ti level or Radeon
8500/9100 level.
1) List your card on E-bay.
2) Take the money from that purchase and buy another card.
That is exactly what I did and I couldn't be happier with the speed increase.
Gil
hi i have been testing today and i have got my memory clock frequency to
513.0mhz
on 3dmark2003 my test score is 1175
on 3dmark2001 my test score is 5971
on 3dmark2000 my test score is7629
on all test i have skipping
you need to use coolbits attacht
sim
begin 666 CoolBits.reg
M4D5'141)5#0*"EM(2T597TQ/0T%,7TU!0TA)3D5<4T]&5%=!4D5<3E9)1$E!
M($-O<G!O<F%T:6]N7$=L;V)A;%Q.=E1W96%K70HB0V]O;$)I=',B/61W;W)D
*.C P,# P,# S"@``
end
The jist of what everyone is saying is you made a very bad( probably
un-informed, no offence) choice for your gfx card. Chalk it up to a lesson
learned and do some research about the gfx card your planning to get next
time. One more thing, if your very lucky and slam some extra after-market
cooling on that lemon you might( just maybe, but probably not) get it up to
290-300/480-500. But it will have to have some really wicked cooling on it.
this
> sim
"sim" <tjohnson200@tiscali.co.uk> wrote in message
news:40897358_2@mk-nntp-2.news.uk.tiscali.com...
> 513.0mhz
If you had managed to scrounge up the Ultra 128bit version of the 5200,
it'll do 10,000+ in 3Dmark01. I built a system for a friend, Barton 2500 @
3200, Nforce2, and against my recommendations, an MSI FX5200 that he thought
was a 128 bit card. Got benchmarks exactly like yours. My Geforce2 GTS Ultra
beat it by 900 on 3DMark01.
On Fri, 23 Apr 2004 20:51:42 +0100, "sim" <tjohnson200@tiscali.co.uk>
>513.0mhz
>sim
you should get in 3dmark03 about 1400-500 ans that without oc your
hardware and blowing up the special feature in it...
with these driver 53.03 plus the nforce 3.13 driver.
but your pc should be like 2600xp cpu + 512megs 333ddr with a nforce2
board
