It is just my first time using Prime95 so I didn't really know how long should I run it. I am just worried with my FX8320 because HWMonitor is showing me that my core temp is around 42C to 45C. When I run Prime95 it went up to 52C. My ambient room temperature here is around 32C to 37C. (really hot)
The 42C to 45C is happening when I am using Chrome maybe like 7 to 10 tabs and 3 remote desktops, skype. That's it.
I am using FX8320 with Hyper 212X. GPU is Zotac GTX 970 which I normally see around 40C to 42C.
And by the way, I installed my cooler horizontally because I was having a hard time installing it vertically. If someone would say my temps aren't normal then I guess it's because of the orientation of my cooler maybe?
Thanks a lot!
Thanks a lot!
