Yes, after years of putting up with my eMachine from 2004, I'm finally building my own PC. I plan on building this sometime next week, and I am hoping to do some pretty decent gaming with it (Crysis, CoD 4/W@W, WoW) w/ my 22" monitor. I have a soft cap of $550 for this PC, and plan on running Windows 7 64-bit in lieu of buying an OS for now. So, without further ado, here is what I have thus far:
CPU: AMD Athlon II X2 250
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103681
MoBo: ASUS M4A78 Plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131381
GPU: Sapphire Radeo HD 4870 512mb
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102810
RAM: Kingston HyperX 4g DDR2 1066Mhz
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104073
PSU&Case Combo: Antec Earthwatts 650W & Antec 300 Illusion
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.215888
Hard Drive: Western Digital Caviar Blue 320GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136098
DVD-Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151188
My plan with this set-up is to run modern games at a respectable capability while also being simple to upgrade in the future. However, as of now, I am more over-budget than I'd like to be (w/shipping, the total comes to $583.22). So, something that came acrossed my mind is to use an external dvd-burner that I use with my netbook instead of buying a new internal one for the time being. The only catch is that it transfers data via USB instead of SATA. Would that make a big difference in performance? Also, any suggestions on replacements would be greatly appreciated.
DVD-Burner
