[SOLVED] 5600xt odd issues persisting, have tried everything I can think of. Please help!
Apr 23, 2021
issues with my 5600xt pretty much since ive had it
-game crashes or alt tabs and gets major screen tear, usually in games like WoW, LoL, Horizon Zero Dawn also crashes my streamlabs if im streaming
- new games have issues with screen tearing often, has happened in Rocket League CSGO and R6 usually fixed through tweaking settings but i cant pinpoint the exact issues
-ive tried DDU fresh installs of multiple different drivers with no luck, when it crashes i get a pop up from AMD software to report the crash but no error message or anything
Is it possible it is not a driver issue? When I get the prompt to report a crash it says AMD has encountered a driver error but no different drivers have worked.
try running a gpu benchmark , or furmark test , to check your gpu.
if it fails the tests , then u have a faulty card
also check the GPU temp too
and for screen tearing , enable Vsync .
will do, ill let ya know how it goes. thanks for the advice. i think im just going to switch to nvidia for graphics if i can find a 3080 like you.
