560ti Issue, 1 fps on furmark
ihavetissues
Hi Everyone,
I recently tried to get back into gaming but when trying to play CS:GO suffered unplayable lag, tried player unknown battlegrounds and having the same low fps making the game unplayable. Just in the CS:GO menu screen I'm getting 18/19 FPS then when in game literally 1 FPS. I ran up Furmark and got the following results:
SCORE:30 points (1 FPS, 60000 ms)
Max GPU Temp: 28°C
Resolution: 1280x1024 (FS) - AA:8 samples
FPS: min:1, max:3, avg:1 - OPTIONS: DynBkg
GeForce GTX 560 Ti/PCIe/SSE2 (10DE-1200)
Drivers: 22.21.13.8253 (6-7-2017) - GL:nvoglv64
Clocks: GPU core: 50 MHz, memory: 135 MHz
Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
CPU SPeed: 2712 MHz
System Memory: 16304 MB
OS: Windows 10 64-bit build 14393
What on earth is going on?
This is probably too late to help you, but might help some other lost soul with a GTX 560 Ti in 2017. I had the same problem with the 385.69 drivers, and (I suspect it was related) suffered a nasty OS crash. I ended up having to reformat my SSD to reinstall Windows. Fresh install with 385.41 drivers gave the same non-utilization.
I used Display Driver Uninstaller to clean the drivers out and put on the 375.95 drivers, and now my GPU is actually being used as it should be in...
I have just re-installed my drivers with no luck
I used Display Driver Uninstaller to clean the drivers out and put on the 375.95 drivers, and now my GPU is actually being used as it should be in FurMark.
