Hello!
I have a Gigabyte 5700XT OC with a custom fan curve that goes no higher that 60% yet my PC will sometimes reach 71/72 degrees and the fans kick off much higher and then drop. Sometimes the temperature is right on the edge of this trigger so it sounds like a car revving for no reason. Why is the fan curve being ignored? I can turn it all the way down and replicate the issue everytime. The GPU is not even 1 year old.
I have done full uninstalls and reinstalls including using DDU. I don't have MSI afterburner installed at all only the NZXT CAM software for my fans.
Any advice, any body having similar issues? Or shall I simply higher the fans to keep the temperature under this value, I just didn't want the loud noise when I was happy with the temps.
Thanks!
Thanks!
