[SOLVED] 5760x1080 triple monitor...what components.
Jan 14, 2019
Starting to rebuild my pc have around £1000 to spend on gpu cpu mobo and ram. Will be matching the rest of the parts to these after. My question is what would people recommend for games at 5760x1080 60hz/60fps triple screen setup. I would do some light 3d design work.
Atm am heading towards a ryzen 2600x just because of the good value you get bit have always had an Intel before.
Cheers
For 60fps gaming, ryzen 2600X is the perfect choice!
Regarding gpu, 3x1080p is 6.22 million pixels. 4k is 8.29 million pixels. So with that in mind, I would suggest a rtx 2080/gtx 1080ti / or the upcoming Radeon VII.
Sadly, with those gpu, ur budget would probably jump to 1200 range. But that's what I would recommend.
