Hi,
I have a new system from entirely new parts that crashes after about 5-10 hours of playing Wow. It goes straight to a black screen.
I have reinstalled windows from scratch and re built the PC making sure each component is correctly installed.
My specs are
AMD 5800x (stock clock with AIO)
Gigabyte 3070 Gaming OC
Gigabyte AMD B550 AORUS PRO AX
Corsair vengeance rgb pro 3600
EVGA GM 650 Watt 80+ Gold SFX PSU
Gigabyte AORUS 1TB M.2 PCIe 4.0
All parts are brand new. Its a larger mini ITX case and temps seem great. Gaming i seem to hit a max of 60 degrees on CPU. Although I really dont push the PC much. I did experience 2 of the crashes when recording via the geforce experience as well.
My error i got after reboot was this:
Problem Event Name: LiveKernelEvent
Code: 124
Parameter 1: 0
Parameter 2: ffff9e8202577b90
Parameter 3: bc000800
Parameter 4: 1010135
I have also recieved the "Windows was not Shut down properly" with no other indication of fault a couple times.
Any advice? Thanks
My specs are
Code: 124
Parameter 1: 0
Any advice? Thanks
