I've just noticed that although all my 6 cores are maxed out and have been for about 10 minutes (doing some photogrammatry) Core Temp is showing that the processor is only drawing around 55 Watts of power and the average temp of each core is only around 65 degrees C. And to touch the heat sync on the processor is barely warm. Is this normal?
I thought that the processor under load should be consuming around 180W and the temperature of the cores would be a lot higher. I would have thought that if there was a problem then the cores wouldn't be showing 100% utilised.
