I have a 5820K on a GA-X99-UD3, when I built the rig 8 months ago, I set it to 4.2Ghz @ 1.23V, which worked perfect for months. Today, I try going in and stepping to 4.5Ghz @ 1.28V, but it shuts down before getting into windows. So I go back to original 4.2 OC settings, still shuts down before it gets into windows. So I try a 100Mhz overclock @ stock voltage, still shuts down before it gets into windows. It will only boot if I have it at default settings. I am a relatively experienced overclocker, have been doing it on many rigs, and can not figure this out. All I want to do is go back to my 4.2Ghz setting, but not any OC will work, so I cant do that.
Long story short, OC worked perfect before, I try different OC, and now NO OC will work, even a 100Mhz OC. Will not boot unless on default settings.
What the hell happened???
I am using a V1000 PSU and cooling using an H60.
