Hello,
I am looking at a new PC setup and would like to run 3 cloned hdmi/dvi displays all off the same card. I recently found out that even if the card has outputs for each display, the card may not allow all outputs to be used at the same time.
I am deciding between a 5850 and a GTX 460, and from the way I understand it, you can only use 2/3 dvi/hdmi outputs at the same time. Because of this, I would probably not be able to go with the 460 since it seems the only output option is 2 DVI and a mini HDMI (since I cannot use VGA in this setup), and therefore may not be able to clone 3 separate displays at the same time.
However, from what I have found I would be able to run 3 displays with the 5850 by using dvi/hdmi for 2 and then using a displayport to hdmi adapter for the final display.
If anyone can confirm or deny any of this it would be greatly appreciated.
Thank you for your help
