L Leox22 Commendable Dec 2, 2016 32 0 1,540 Nov 14, 2017 #1 I have a question: will a 6+2 pin PCI-e (power) cable fit in a 6 pin gpu. I'm planning on buying the msi gtx 1050ti gaming x which has a 6 pin port and my psu only has a 6+2 pin PCI-e cable. Will it still fit?
Solution sosofm Nov 14, 2017 Yes its ok because the others two pin ( 6+2) can be removed .Is like that https://www.techpowerup.com/forums/attachments/pcie6-2-jpg.57637/
sosofm Splendid Feb 25, 2009 3,910 13 25,165 Nov 14, 2017 Solution #2 Yes its ok because the others two pin ( 6+2) can be removed .Is like that https://www.techpowerup.com/forums/attachments/pcie6-2-jpg.57637/ Upvote 0 Downvote Solution
