C chucky9 Distinguished Nov 3, 2013 548 5 19,015 Aug 14, 2014 #1 so im looking for a 6 fan controller than can support 5 140mm fans + a 200mm fan i will most likely be using a mixture of noctua and noctua industrial
Solution EasyLover Aug 14, 2014 There are many: http://www.newegg.com/Product/Product.aspx?Item=N82E16811992012&cm_re=fan_controller-_-11-992-012-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16811981005&cm_re=fan_controller-_-11-981-005-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16811999171&cm_re=fan_controller-_-11-999-171-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16811992014&cm_re=fan_controller-_-11-992-014-_-Product http://www.amazon.com/Sunbeamtech-PL-RS-6-Rheosmart-Fan-Controller/dp/B004LKZESI/ref=sr_1_10?s=pc&ie=UTF8&qid=1407997776&sr=1-10&keywords=Fan+Controller
EasyLover Splendid Dec 30, 2013 6,551 0 24,960 Aug 14, 2014 Solution #2 There are many: http://www.newegg.com/Product/Product.aspx?Item=N82E16811992012&cm_re=fan_controller-_-11-992-012-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16811981005&cm_re=fan_controller-_-11-981-005-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16811999171&cm_re=fan_controller-_-11-999-171-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16811992014&cm_re=fan_controller-_-11-992-014-_-Product http://www.amazon.com/Sunbeamtech-PL-RS-6-Rheosmart-Fan-Controller/dp/B004LKZESI/ref=sr_1_10?s=pc&ie=UTF8&qid=1407997776&sr=1-10&keywords=Fan+Controller Upvote 0 Downvote Solution
