I'm building a 6 GPU rig with an Asus Z270-AR. All of the GPU's are connected to the motherboard via USB PCI 1x to 16x riser cards, powered by molex connectors.
I've been doing some testing, and I can sometimes get it to boot with 5 out of the 6 GPU's fully functional. The strange thing is that it isn't one single GPU that makes it not boot, it seems to be that it just can't do all 6 at once. When unplugging them and restarting the pc one by one, I found that in most of the cases, 5 GPU's still doesn't work, but every few times, it will work. Using only 4 GPU's always seems to work.
Then, when I unplug all the others and just test the one that turned out to be the problem, it works totally fine. When I plug in all 6 at once again, it doesn't work, and this time a completely different GPU is determined to be the problem. When I test that one alone, it is also totally fine.
The screen I see when it fails is this: http://i.imgur.com/cRgiaqT.jpg
Windows is already fully installed and functional, and when I reduce the amount of GPU's it boots correctly. When I press escape as it suggests, it simply restarts the machine and brings me back to the same screen.
I'm at a loss, power definitely shouldn't be an issue since I have a beefy 1200W power supply and these are quite efficient GTX 1070's. The cards all light up and their fans spin so they all have power.
Also, this rig does not have a case, it is just a motherboard, CPU, an SSD, and GPU's in open air.
Thanks in advance for your effort.
