Hello, in the past 3 months, I have had 3 GPU's that all within the span of a couple weeks-months start crashing in all 3D applications, citing rendering device lost, checking event viewer says
"The description for Event ID 0 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer, the display information had to be saved with the event. The following information was included with the event: \Device\Video3 Error occurred on GPUID: b00 The message resource is present but the message was not found in the message table"
This started when I bought a used 3080 and a MSI a1000g PSU to power and it lasted 3 weeks before this error occurred.
Another weird thing is swapping in my 1070 presents no issues and runs perfectly fine.
Things I've tried:
Going into the registry and changing the TdrDelay to a higher number.
Reinstalling Windows
New Graphics Cards
DDU Clean Install of new and old drivers
Undervolting
Can anyone help? I don't want the newest GPU to be corrupted if that's whats happening.
Mobo: Asus Strix B550-F Gaming
CPU: Ryzen 7 5800x
PSU: MSI A100G ATX 3.0
RAM: 16Gb G.Skill F43200
Things I've tried:
New Graphics Cards
Undervolting
CPU: Ryzen 7 5800x
