6-pin connector on power supply?
00maxse
109
I'm going to upgrade to a PCI-E motherboard, so I need a 24 pin power supply. But do all the PCI-E cards use the 6pin power connectors and not the 4pin? Because I don't have any 6pin connectors with my current power supply. I have a ChiefMax 650W.
I dont think that i would worry too much about it. Since the 6 pin connector is required for PCI-E im sure that there is a connector included with the video card that would plug into a regular 4 pin molex connector. I could be wrong though, i havent ever bought a PCI-E card.
Yes, Im almost positive that all pci-e card has molex to 6-pin connector cabel but double check. It depends on the brand or model. I know for the fact the BFG 7800 GT and GTX has them.
I dont know if the MSI one comes with the splitter, i will check my box when i get home. although i have the ATi one im sure that the cables supplied are pretty much the same. If it dosnt come with one im sure you can buy one for a small price.
