6-Pin Fan Connector
Aug 10, 2018
The case fans I want (Aigo Aurora) use a 6-pin connector but my motherboard (MSI X370) only has 3/4-pin connectors. Is there any way or adapter I can use to have the 2 work hand in hand?
Oh so the controller that comes with the package is what I connect the fans to? and then I can connect the controller to my motherboard?
Looks like it doesn't connect to the motherboard, the controller in the link I posted uses a temp sensor to control fan speed.
Ohhh I see, so where does it get power from?
