A astrofighter122 Honorable Mar 31, 2015 282 0 10,780 Jun 4, 2015 #1 Hi, does the HP p6741c-b have a 6-pin power connector for a GPU upgrade?
Solution scout_03 Jun 4, 2015 with a 250 watts psu in i dont see anywhere a gpu power cable you will need a low power gpu if you want to upgrade .
scout_03 Titan Ambassador Feb 18, 2010 30,587 324 107,640 Jun 4, 2015 Solution #2 with a 250 watts psu in i dont see anywhere a gpu power cable you will need a low power gpu if you want to upgrade . Upvote 0 Downvote Solution
A astrofighter122 Honorable Mar 31, 2015 282 0 10,780 Jun 5, 2015 #3 scout_03 : with a 250 watts psu in i dont see anywhere a gpu power cable you will need a low power gpu if you want to upgrade . What high-end GPU would be low-power? Upvote 0 Downvote
scout_03 Titan Ambassador Feb 18, 2010 30,587 324 107,640 Jun 5, 2015 #4 over mid range gpu they all use power cable from a 6 pins and minimum i seen ask for a 300 watts without power cable that is the gtx 750 ot the gtx 750 ti . Upvote 0 Downvote
