I plan on installing two 8-Way PWM Splitters to power a total of 12 radiator fans. One splitter to power 8 fans and the other to power 4. My questions are:
1. Should I connect both 8-Way PWM Splitters to the same 6 pin SATA cable going to the psu? Or should I use two separate 6 pin SATA cables - one for each 8-Way PWM Splitter? That is does one 6 pin SATA outlet supply adequate power for both splitters? And if so is one 6 pin SATA cable adequate to supply this power to both splitters?
Or 2. Can I use one Swiftech 8-Way PWM Splitter from one 6 pin SATA cable for all 12 fans by connecting Y-splitters to the 8-Way Splitter? This concerns me because it says up to 8 devices in the product description.
PWM Splitter:
https://www.amazon.com/gp/product/B00IF6R4C8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Fans:
https://www.amazon.com/dp/B01N0GRQD2/ref=dp_prsubs_1
psu:
https://www.evga.com/products/product.aspx?pn=220-T2-1000-X1
PWM Splitter:
Fans:
psu:
