60 Degrees no case fans
Its within tolerance for most cards and processors, but if this is at system idle - it's too high.
Why wouldn't you have any case fans??? I don't mean to be rude, but that's just plain silly. That's like putting Hot Soup in a fridge that isn't running - it make things hot inside the fridge!
You can find fans on Amazon for like 10 bucks. I suggest you buy fans because the inside of your computer will start to generate alot of heat which is bad for the components, you need fans to cool your system.
