600va ups not running a single laptop for 1min, Why???
faultyos
5
hey everyone this may be a repeated question.. but i really need help
Problem is i am trying to run an old laptop hp-compaq on a ups as the laptop battery is dead.
the ups only provides backup of 50-60sec, i am not able to figure out whats happening,
i tried to switch to my another ups but the same thing happens.
i have a numeric ups 600va
and an i ball usp 600va
config of i ball are
Capacity - 600VA / Single PC load
Microprocessor Controlled - Microprocessor controlled to guarantee high reliability
Input Voltage - 230VAC
Input Voltage Range - 140-300VAC
Output Voltage - 230VAC
Output Voltage Regulation (Batt.) - ±10%
Output Frequency - > 40Hz
Output Frequency Regulation (Batt.) - 50±1Hz
Output Waveform - Modified Sine-wave
Battery Type - 12V7AH x 1
Recharge Time - 6 hours to charge 90% at normal mode
Transfer Time - 6ms - Nominal / 10 ms - Maximum
LED Indicator - Green, Red and Amber LEDs for various indication modes
Audible Alarm - Beeper with various beeper modes
Full Protection - Discharge, overcharge, and overload protection
Power Outlets - 3-Pin x 3
Dimension (D x W x H) - 278 x 100 x 143 mm
Net Weight - 4.4 Kg
probably numeric must be having near about config
laptop adapter :
hp laptop charger input: 100-240v 1.6A 50-60hz
output 18.5V 3.53A
rated 65 W charger.
laptop is compaq pesario v3000.
Please guide me what is wrong,
ups battery are new as i changed it about a month ago.
Now what might be the problem.
Thanks for the reply,
i know that its just like plugging into AC, but still the ups usually gives a backup of 10-15min to a single desktop pc,(approx load 220W)
i expect the ups to give at least backup for 5 min.
forgive me for the ignorance, if i am expecting something that i should not and please point me in the right direction, so i can understand the basics.:)
i mean laptop is working perfectly, but when the electricity goes off, ups is only able to support the laptop for mear 50 to 60 sec....
What is the problem with the ups...
Could be the batteries in the UPS need replacing 'cos they are no longer holding a charge, same with the other UPS you tried.
Thanks for the patience and support from you guys,
I would like to mention,
1. My UPS Battery's are New.
2. Laptop is fully functional without its battery, (Its an old laptop around 10yr old, so i cant get a new battery for it)
3. The problem is probably with the UPS Circuit as its only giving backup of 1 min, that means ups is shutting down while there is still enough juice left inside the battery...
Thanks for the effort.
