600W or 700W for my system?
kikoano111
141
I have
This is the parts I will buy:
CPU Core i7-4770 Quad 3.4GHz LGA 1150 8MB Box
2 X DIMM 8GB DDR3 1600MHz Kingston HyperX XMP Beast
HDD 3.5" 3TB Toshiba SATA3 7200rpm 64MB
ATX Midi Tower Case Gigabyte GZ-G1P1 Black
DVD RW BluRay LG 14x SATA Black
Gigabyte PCX GeForce GTX770 4GB GDDR5 HDMI/2xDVI/DP Overclock
MB Gigabyte H87-HD3 LGA1150 DDR3 3000MHz SATA3 USB3.0 Ultra Durable4 Plus HDMI/DVI/VGA
PSU 700W CoolerMaster G-Series RS-700-ACAAB1-EU or PSU 600W CoolerMaster G-Series RS-600-ACAAB1-EU ?
Dark Lord of Tech
Speedy Gonzales
Get this SEASONIC made unit , the Coolermaster is poor quality.
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ NCIX US)
Total: $59.99
(Generated by PCPartPicker 2014-01-02 20:24 EST-0500)
Or if you want room for upgrades.
Power Supply: EVGA SuperNOVA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.99 @ NCIX US)
Total: $69.99
(Generated by PCPartPicker 2014-01-02 20:26 EST-0500)
t1nfoilh4t
66
8
if you will have money to go for sli in the next few years you should go with the 700w to hit the sweet spot for psu utilization. If you intend to keep that gpu or upgrade to a different single gpu solution in the future you should get the 600w one since it will run more efficient and more stable, even if its the same psu as the 700w model.
kikoano111
141
I cant buy them only this 2 I am not buying online.
kikoano111
141
It says 6/8 pin PEG is that 6/8 pin PCIE X2?
Similar threads
