Here's what cruicial.com says about it when I do the system scanner:
Your D945GTP System Specs
Scan Id: 7E9B39F731D926C3
Memory😀DR2 PC2-6400, DDR2 PC2-5300
Memory Type: DDR2 PC2-6400, DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 4GB
Currently Installed Memory: 6GB
Total Memory Slots: 4
Available Memory Slots: 0
2GB
DDR PC2-64001GB
DDR PC2-64002GB
DDR PC2-64001GB
DDR PC2-6400
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found here.
Memory or DRAM is the 'working' memory of the computer. It's used to store data for programs (sequences of instructions) on a temporary basis.
video - installing memory
Storage:SATA 2 - 3Gb/s
7% Full (466 GB Total Storage)
SATA Version -- SATA 2 - 3Gb/s
Storage Drives -- hard drives and solid state drives -- are the permanent memory for the programs and documents on your computer.
Data Transfer Rate is the rate at which data can be sent or received. This is determined by your motherboard. A drive with a higher transfer rate will only run at the rate of the motherboard's transfer rate.
Cache is a type of working memory that allows the drive to perform faster.
RPM is the rotations per minute of a hard drive which effects the speed of data transfer.
Solid State Drives are non-moving memory, so access speed is instant.
