64-bit VIsta HARD Freeze/lock ups randomly
Phils08DK
8
I bought a custom made desktop with Vista 64-bit OS, All motherboard drivers, OS patches, and BIOS are updated with the right and current 64-bit updates. Device manager shows no conflicts or anything.
We have not overclocked this comp at all, and not sure if we want it overclocked, we just want this comp to run without these freeze ups, been suffering like this since day 1.
Comp just locks up randomly sometimes as much as 4 times a day. Had the comp for about 8 months, and it used to do it once in awhile but now seems to want to do it alot more often then usual, graphics cards was put under a stress test, even tested comp with 1 at a time, ran a program to test it and they both tested perfect, Disabled SLI tested comp to see if it would freeze up, and it did, re-enabled SLI, and it did it again later that night, so every option we tried it never helped. Also as a little more detail, it seems to freeze alot faster if I'm watching a video from say youtube.com or gametrailers.com. Ram was tested as well and everything was perfect.
The following is the details on the set up..
Manufacturer: ASUSTeK Computer INC.
Processor: Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz (4 CPUs), ~2.5GHz
Memory: 4094MB RAM
Hard Drive: 750 GB
Video Card: NVIDIA GeForce 8800 GT (2)
I read in a thread that someone that had this sort of issue and someone recommended HWmonitor and to post the findings after letting it run for a few hours.
This is the results of the test.
Voltage sensor 0 1.23 Volts [0x4D] (CPU VCORE)
Voltage sensor 1 3.30 Volts [0xCE] (VIN1)
Voltage sensor 3 4.84 Volts [0xB4] (+5V)
Voltage sensor 4 12.22 Volts [0xBF] (+12V)
Voltage sensor 7 4.95 Volts [0xB8] (+5V VCCH)
Voltage sensor 8 3.22 Volts [0xC9] (VBAT)
Temperature sensor 0 57°C (134°F) [0x39] (TMPIN0)
Temperature sensor 1 42°C (107°F) [0x2A] (TMPIN1)
Temperature sensor 2 11°C (51°F) [0xB] (TMPIN2)
Fan sensor 0 2872 RPM [0xEB] (FANIN0)
ACPI hardware monitor
Temperature sensor 0 40°C (104°F) [0xC3C] (THRM)
Intel Core 2 Quad Q9300 hardware monitor
Temperature sensor 0 62°C (143°F) [0x26] (Core #0)
Temperature sensor 1 62°C (143°F) [0x26] (Core #1)
Temperature sensor 2 59°C (138°F) [0x29] (Core #2)
Temperature sensor 3 58°C (136°F) [0x2A] (Core #3)
Processors Information
Processor 1 (ID = 0)
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core 2 Quad Q9300
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz
Package Socket 775 LGA (platform ID = 4h)
CPUID 6.7.7
Extended CPUID 6.17
Core Stepping M1
Technology 45 nm
Core Speed 2500.0 MHz (7.5 x 333.3 MHz)
Rated Bus speed 1333.3 MHz
Stock frequency 2500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 7.5x
max VID 1.225 V
Features XD, VT
Display Adapter
Name GeForce 8800 GT
Display Adapter
Just trying to get to the bottom of this issue, I just want this comp to run the way its supposed to. Any additional info you need let me know, I'm not a computer whiz so bare with me on this.
I posted this issue on a few different forums and no one has been able to even get close to reducing the lock ups/hard freezing issues. One forum said try toms hardware, if they cant figure it out then no one can... So thats why i am here.
heres a pic of the reliability monitor if that helps at all.
Download and install CPUZ. Check the memory tab to see if the speed and timings match your memory's manufacturer's specifications. Check the SPD tab for proper voltage required. In BIOS, manually bump up the RAM voltage. Set the speed and timings to Mfg. specs. Otherwise, BIOS will default RAM voltage to JEDEC standard. The RAM may require more voltage than standard. RAM is often the cause of system crashes and lock ups when running software (games).
I think I did that, as thats where I got the info I posted above, HWmonitor, CPUID Hardware monitor if thats the same thing as I have installed on my comp, and everything checked out fine there voltage wise at least. Will check into it to make sure, but the RAM was set to mfg specs, then bumped up and tested for lock ups and it still did it. Any other ideas I can look into while I recheck it?
Install CPU-Z 1.51 set up on the page I linked. The information you linked has no menton of your RAM voltage, timings and speed. Also, the voltages from the PSU look a little suspect. Like there may some excessive 'spike' or instability going on.
Here is what CPU-Z has come up with, its a large amount of text, didn't see any other options to put the info in here seems last 2 posts i tried and failed, and cant delete them for some reason. Take a look at it and tell me what you think. I will try to get the info on the PSU as well, but as far as I know its either 1050w, or over 1050w. Thanks badge, I appreciate this!
CPU-Z version 1.51
Codename Yorkfield
CPUID 6.7.7
Extended CPUID 6.17
Core Stepping M1
Technology 45 nm
FID/VID Control yes
max VID 1.225 V
Features XD, VT
Chipset
Northbridge NVIDIA nForce 780i SLI SPP rev. A2
Southbridge NVIDIA nForce 780i SLI MCP rev. A3
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 400.0 MHz (5:6)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 23
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number DQVE1B16
Manufacturing date Week 16/Year 08
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 200 266 400
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 5
RAS# Precharge 3 4 5
TRAS 9 12 18
TRC 12 16 23
DIMM #2
General
Memory type DDR2
Size 2048 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 18
TRC 12 16 23
Monitoring
Mainboard Model P5N-T DELUXE (0x33B - 0xBE5D88A0)
Hardware monitor
ITE IT87 hardware monitor
Voltage sensor 8 3.07 Volts [0xC0] (VBAT)
Temperature sensor 0 36°C (96°F) [0x24] (TMPIN0)
Temperature sensor 1 37°C (98°F) [0x25] (TMPIN1)
Temperature sensor 2 13°C (55°F) [0xD] (TMPIN2)
Fan sensor 0 2778 RPM [0xF3] (FANIN0)
Hardware monitor
Analog Device ADP3228 hardware monitor
Current sensor 0 5.69 Amps [0x2C] (CPU)
Power sensor 0 7.18 W [0x688] (CPU)
Dump hardware monitor
SMBus Register space, base address = 0x01C80
SMBus request at channel 0x0, address 0x20
Hardware monitor
Temperature sensor 0 57°C (134°F) [0x2B] (Core #0)
Temperature sensor 1 57°C (134°F) [0x2B] (Core #1)
Temperature sensor 2 56°C (132°F) [0x2C] (Core #2)
Temperature sensor 3 55°C (130°F) [0x2D] (Core #3)
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version ASUS P5N-T DELUXE ACPI BIOS Revision 1402
date 01/22/2009
DMI Processor
manufacturer Intel
model Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz
clock speed 2500.0 MHz
FSB speed 333.0 MHz
multiplier 7.5x
Display Adapter(s)
Device number 0
Vendor ID 0x10DE (0x10DE)
Model ID 0x611 (0x53C)
Revision ID 0xA2
Perf Level 3D Applications
GPU core clock 600.0 MHz
GPU shaders clock 1500.0 MHz
GPU memory clock 900.0 MHz
Device number 1
Revision ID 0xA2
If the computer is locking up, the most likely cause is a driver or process. You're going to have to narrow down the possibilities. For example: Unplug any accessories you have on the computer - USB Devices, external drives, etc.. See does that work. If it does, you now have a much shorter list of things to troubleshoot, yah?
Troubleshooting Sequence:
http://www.vistax64.com/tutorials/101393-repair-vista-options-preferred-sequence.html
How to generate a system health report:
http://www.vistax64.com/tutorials/82728-system-health-report.html
checking the Reliability Monitor for errors:
http://www.vistax64.com/tutorials/69535-reliabilty-monitor.html
How to check system files in Vista:
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
How to perform a Startup repair:
http://www.vistax64.com/tutorials/91467-startup-repair.html
How to perform a full system repair:
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
Suggestions to Improve Performance
http://www.vistax64.com/tutorials/81176-speed-up-performance-vista.html
Process Monitor (Task Manager on steroids)
http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
