Ok here is the info I got back from coretemp and hwmonitor. I copied the HWmonitor stuff directly below. Coretemp would only save a .png file to view, so it showed these values.
Processor 0
Tj. Max 100*C
Core 0 64*C
Core 1 54*C
Core 2 60*C
Core 3 74*C
Processor 1
Tj. Max 100*C
Core 0 53*C
Core 1 53*C
Core 2 61*C
Core 3 61*C
And now the HW Monitor report
CPUID HWMonitor Report
Binaries
HWMonitor version 1.1.7.0
Monitoring
Mainboard Model S5375 (0x00000127 - 0x0002A4D0)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83627DHG
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xA0
LPCIO Revision ID 0x25
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 A0 25 FF 00 44 00 00 FF 70 00 02 00 03 01 00 FF
30 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware Monitors
Hardware monitor Winbond W83793
Voltage 1 3.62 Volts [0xE2] (AUX)
Voltage 2 2.16 Volts [0x87] (VIN2)
Voltage 4 -5.62 Volts [0x71] (-12V)
Voltage 5 1.46 Volts [0x5B] (VIN5)
Voltage 6 3.28 Volts [0xCD] (+3.3V)
Voltage 7 8.03 Volts [0x84] (+12V)
Voltage 8 5.46 Volts [0xCB] (+5V)
Voltage 9 5.56 Volts [0xCF] (+5VSB)
Temperature 0 30°C (86°F) [0x1E] (TMPIN0)
Temperature 1 17°C (62°F) [0x11] (TMPIN1)
Temperature 4 35°C (95°F) [0x23] (TMPIN4)
Fan 3 3924 RPM [0x158] (FANIN3)
Fan 4 3719 RPM [0x16B] (FANIN4)
Fan 5 2009 RPM [0x2A0] (FANIN5)
Fan 6 2012 RPM [0x29F] (FANIN6)
Fan 7 2042 RPM [0x295] (FANIN7)
Register space SMBus, base address = 0x0400
SMBus request channel 0x0, address 0x2F
00 80 00 00 00 00 0F AF 0F BF 64 64 5E 73 5C 7B 12
10 00 E2 87 FF 71 5B CD 84 CB CF 00 34 1D 14 00 00
20 23 27 00 0F FF 0F FF 0F FF 01 63 01 76 02 9F 02
30 A0 02 A1 0F FF 0F FF 0F FF 0F FF FF FF FF FF FF
40 01 00 00 00 00 00 F7 FF 1F 7C 3F 00 00 00 20 00
50 12 00 00 00 00 00 00 00 28 01 00 00 7F 00 0F 03
60 FF 00 FF 00 FF 00 FF FF 3F 00 FF 00 FF 00 FF 00
70 FF 00 FF 00 FF 00 FF 00 64 5F 55 50 64 5F 55 50
80 64 5F 55 50 64 5F 55 50 64 5F 55 50 64 5F 55 50
90 FF FF FF FF FF FF 06 97 06 97 06 97 06 97 06 97
A0 FF FF FF FF FF FF FF FF 30 30 00 00 00 00 FF FF
B0 00 00 3F 3F 3F 3F 3F 3F 3F 3F 3F 89 89 89 89 89
C0 89 89 89 06 06 7F FF 00 00 FF FF FF FF FF FF FF
D0 F0 46 46 46 46 10 C0 FF F5 C0 F3 80 80 01 80 01
E0 BB C0 82 FE 80 E8 FB FC FD FD A8 C0 FF FF FF FF
F0 00 00 00 00 00 00 60 80 1B 00 FF 00 00 10 00 00
Hardware monitor Winbond W83627DHG
Voltage 0 1.09 Volts [0x88] (CPU VCORE)
Voltage 1 1.82 Volts [0xE3] (VIN1)
Voltage 2 3.26 Volts [0xCC] (+3.3V)
Voltage 3 4.90 Volts [0xCC] (+5V)
Voltage 4 8.59 Volts [0x9A] (+12V)
Voltage 5 1.46 Volts [0xB6] (VIN5)
Voltage 6 1.09 Volts [0x88] (VIN6)
Temperature 0 42°C (107°F) [0x2A] (SYSTIN)
Temperature 1 49°C (119°F) [0x61] (CPUTIN)
Temperature 2 35°C (95°F) [0x46] (AUXTIN)
Hardware registers
SMBus request channel 0x0, address 0x2D
bank 0
00 80 FF 04 7F 01 00 00 00 01 01 01 01 3C 3C 0A 0A
10 04 FF 00 00 00 01 01 3C 43 07 00 00 FF FF FF DA
20 89 E3 CC CC 9A B6 88 2A FF FF FF DA 00 3E B7 FF
30 B7 7F B3 D6 F7 B7 8D FE E7 5B FE FF 77 CF 95 FF
40 03 AA 1B FF FF FF 07 F5 2D 00 00 C4 10 95 00 A3
50 FF FF 00 FF FF FF 00 80 C1 70 FF FF 19 E1 04 05
60 04 7F 40 00 01 01 3C FF 01 FF 01 FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 80 FF 04 7F 01 00 00 00 01 01 01 01 3C 3C 0A 0A
90 04 FF 00 00 00 01 01 3C 43 07 00 00 FF FF FF C2
A0 89 E3 CC CC 9A B6 88 2A FF FF FF DA 00 3E B7 FF
B0 B7 7F B3 D6 F7 B7 8D FE E7 5B FE FF 77 CF 95 FF
C0 03 AA 1B FF FF FF 07 F5 2D 00 00 C4 10 95 00 A3
D0 FF FF 00 FF FF FF 00 80 C1 70 FF FF 19 E1 04 05
E0 04 7F 40 00 01 01 3C FF 01 FF 01 FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 1
50 30 80 00 4B 00 50 00 8A FF FF FF FF FF FF FF FF
bank 2
50 23 00 00 4B 00 50 1B D0 FF FF FF FF FF FF FF FF
bank 3
50 01 05 06 04 00 07 03 06 04 05 00 E0 32 05 00 00
bank 4
50 3B 13 FF 00 00 C3 00 00 4D 8A 1D 9B 09 5C 20 7F
Hardware monitor NVIDIA NVAPI
Voltage 0 0.00 Volts [0x0] (VIN0)
Temperature 0 58°C (136°F) [0x3A] (TMPIN0)
Fan PWM 0 30 pc [0x1E] (FANPWMIN0)
Processors
Number of processors 2
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
Processor 1
-- Core 0
-- Thread 0 4
-- Core 1
-- Thread 0 5
-- Core 2
-- Thread 0 6
-- Core 3
-- Thread 0 7
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Xeon L5420
Codename Harpertown
Specification Intel(R) Xeon(R) CPU L5420 @ 2.50GHz
Package (platform ID) Socket 771 LGA (0x6)
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping C0
Technology 45 nm
Core Speed 2493.7 MHz
Multiplier x FSB 7.5 x 332.5 MHz
Rated Bus speed 1330.0 MHz
Stock frequency 2500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 7.5x
Max VID 1.113 V
Processor 2 ID = 1
Codename Harpertown
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping C0
Technology 45 nm
FID/VID Control yes
Max VID 1.113 V
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008003h
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 6 MB, 2 thread(s)
CPUID
0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00010676 0x00040800 0x000CE3BD 0xBFEBFBFF
0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB4304E
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x0C000121 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x0C000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x0C004143 0x05C0003F 0x00000FFF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x00002220
0x00000006 0x00000001 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000400 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20100800
0x80000002 0x65746E49 0x2952286C 0x6F655820 0x2952286E
0x80000003 0x55504320 0x20202020 0x20202020 0x4C202020
0x80000004 0x30323435 0x20402020 0x30352E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x18008040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003026 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x00000017 0x00180000 0x88E44717
MSR 0x000000CD 0x00000000 0x00000804
MSR 0x0000003F 0x00000000 0x00000000
MSR 0x000000CE 0x00164717 0x7F7F0610
MSR 0x000001A0 0x00000040 0x60962489
MSR 0x000000EE 0x04000000 0x877D4B01
MSR 0x0000011E 0x00000000 0xBE702111
MSR 0x0000019C 0x00000000 0x88230000
MSR 0x00000198 0x47174717 0x06004717
MSR 0x00000199 0x00000000 0x00004717
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008003h
CPUID
0x00000001 0x00010676 0x01040800 0x000CE3BD 0xBFEBFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x0000019C 0x00000000 0x882F0000
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01008003h
CPUID
0x00000001 0x00010676 0x02040800 0x000CE3BD 0xBFEBFBFF
MSR 0x0000019C 0x00000000 0x88290000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01008003h
CPUID
0x00000001 0x00010676 0x03040800 0x000CE3BD 0xBFEBFBFF
MSR 0x0000019C 0x00000000 0x881A0000
CPU Thread 4
APIC ID 4
Topology Processor ID 1, Core ID 0, Thread ID 0
Type 01008003h
CPUID
0x00000001 0x00010676 0x04040800 0x000CE3BD 0xBFEBFBFF
MSR 0x0000019C 0x00000000 0x882E0000
CPU Thread 5
APIC ID 5
Topology Processor ID 1, Core ID 1, Thread ID 0
Type 01008003h
CPUID
0x00000001 0x00010676 0x05040800 0x000CE3BD 0xBFEBFBFF
CPU Thread 6
APIC ID 6
Topology Processor ID 1, Core ID 2, Thread ID 0
Type 01008003h
CPUID
0x00000001 0x00010676 0x06040800 0x000CE3BD 0xBFEBFBFF
MSR 0x0000019C 0x00000000 0x88270000
CPU Thread 7
APIC ID 7
Topology Processor ID 1, Core ID 3, Thread ID 0
Type 01008003h
CPUID
0x00000001 0x00010676 0x07040800 0x000CE3BD 0xBFEBFBFF
Storage
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC52B
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x093A, product=0x2621
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x056A, product=0x00B5
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x18CA (0x18CA)
Model ID 0x0020 (0x0020)
Display adapter 1
Name NVIDIA GeForce 8800 GT
Revision A2
Codename G92
Technology 65 nm
PCI device bus 9 (0x9), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x10DE)
Model ID 0x0611 (0x053C)
So, it does appear those are the actual readings. Again this is at idle with the case cover removed. Currently it is about 74*F in my room. All the fans appear to be running and I think they are at high speed right now too. Even the video card is running a little hot at 54*C or so. Performance on the machine has been generally ok, I just have been pretty wary or these high temps
