Go for a 550w unit from seasonic or corsair. It's still overkill but will most likely outlast your current build and has enough headroom for a stronger gpu if needed.
It's actually overkill. You're probably wasting more power than you need.
That's what I thought. The problem is, the store that I'm going to purchase my parts doesn't have any other parts than this psu. Is it going to affect my pc's performance if my psu is overkill?
No, the PSU will only supply as much power that is needed.
