Question 6600 xt has low clockspeed and low usage in games
Denkata121
163
9
Recently got a 6600xt Red Devil and for some reason my GPU in less demanding games doesnt go above 50mhz. I updated drivers checked software and i still dont get it. Hope someone can help out.
You need to provide FULL PC specs first of all. If the game is less demanding, then it won't tax your GPU too much. The CPU also comes into play here, and the screen resolution applied. How is the performance in graphic demanding games ??.
-1. "Complete" system specs should ALWAYS be accompanied with any driver, hardware, or performance question. Do not post DXDiag reports as they contain a TON of useless information. Posting a DxDiag in place of a System Spec List tends to ward off potential members from helping you.
Please supply the following system details/information, as much as possible (not necessary to provide every detail):
(Complete System Specs)
-CPU make and model# (clock speed/voltage, type of cooler, and "Core" temperature @ idle and load)
-Motherboard make & model# (include Bios version if graphics card is not recognized or you are having stability issues)
-RAM (amount, clock speed, model#/link of kit, configuration)
-Graphics card(s) make and model# (clock speed, voltage if modified, Driver version and GPU temp both @ idle and load)
-Power supply make,model#, "AND" age (note if using 110V or 220V A/C input)
-HDD/SSD configuration (ie: Raid setup/ back up/ OS drive/etc..)
-Case/Chasis make,model# (fan make, model#, and configuration if having thermal issues)
-Operating System (If using Windows note Framework and service pack version)
-Monitor make, model#, and resolution (If model# is unknown list resolution and refresh rate)
*If the unit is a "laptop" or "All-in-one" system you must note the make and model# of the unit. Be sure you are ALWAYS using the OEM/manufacturer's Driver updates for the unit.
*If "Crashing":
-Note the nature of the "crash" in detail, as there are several definitions for the word "crash".
*If "performance" related issue:
-Note the "exact" point in which the performance reduction occurred (ie: After Windows update, After Bios update, After Driver update, After thermal system shutdown, After Hardware change/upgrade etc...)
*For diagnostic purposes please disable the following:
-Any/all Antivirus/ Anti-malware software
-Any/all OSD monitoring software
-ALL overclocks outside of factory spec
Denkata121
163
9
The game in this scenario is "Fistful of frags" also happens in "Snow runner", but to a lesser extent still lower then expected clockspeeds tho.
r5 2600x stock cooler
asrock b450m pro4-f
g.skill aegiss 16gb dual channel 3200
red devil 6600xt latest driver
be quiet system power 9 600w maybe 2 years
kingston a400 250gb ssd -os
barracuda 2tb hdd
mattexx 55 mesh
windows 10 latest update
2 monitors : 1-75hz 1080p ; 2-60hz 1080p
