6600k gtx 1060 build. need some advice
Komamo
9
Hey Guys,
i wanna buy a new pc tomorrow after hesitating 6 months or more.
i already have a case(sharkoon vaya atx), 650 watt psu and a hdd.
now here is what i want to get:
----- € 229,85 Intel Core i5 6600K 4x 3.50GHz So.1151 WOF
----- € 99,12 MSI Z170-A PRO Intel Z170 So.1151 Dual (no idea what to look for on a mb)
----- € 259,48 6144MB EVGA GeForce GTX 1060 GAMING Aktiv
----- € 74,85 16GB G.Skill RipJaws V rot DDR4-2400 DIMM
----- € 32,85 EKL Alpenföhn Brocken ECO Tower Cooler (i have no idea wich cooler to buy but the
maxheight is 15,5cm)
is the combination of hardware ok?
thanks in advance, Komamo
all good, never heard of that cpu cooler though
try to get a cryorig h7, great price/performance and only 14.5 cm tall
Yes, it's ok.
But i found a bit overpriced the MB, if you have no reason to go for that MB, i would try to choice a cheaper one and maybe try to upgrade with that money and a bit more the 1060 to a 1070.
Also i dont known if the ram is in 2x8Gb or a 1x16Gb, if its the lattest switch to 2x8Gb to use a Dual Channel configuration.
The CPU cooler i could not say anything as i dont known it, but i would choice a Noctua NH D14.
i'm an idiot man. i switched the cpu and motherboard price 😀 sorry!
