Question 6700 XT vs 3070 RTX, raw power?
Aug 5, 2021
40
yeetbucket
Proper
Jan 14, 2021
161
29
120
FSR will never make up for the performance slice of turning on RT, because AMD cards are not designed for that. AMD Cards are designed in mind of rasterization, and that is that for the 6000 series.
Aug 5, 2021
40
3070 is more powerful and DLSS is miles ahead of FSR
I read multiple technical sources saying 6700 XT raw performance power / ability is actually around RTX 3080, so once games will be AMD optimized (consoles all AMD, so most games sooner may), we will see 6700XT at 3070-3080 zone, what your thoughts on this?
Aug 5, 2021
40
As I understood from a PC engineer/dev, RT soon enough will be much easier to work with, and wont be Nvidia "best" anymore, as RT will be more software based and run on any GPU. Now RT is mostly developed for Nvidia RT cores. Also he said, once the AMD tweaks and FSR comes and shines into the games, we have all the reasons to see 6700 XT running at 3080 zone.
I also think, FSR now at 1.0 and already some games showing better quality than DLSS, like: https://www.reddit.com/r/nvidia/comments/otewu3 View: https://www.reddit.com/r/nvidia/comments/otewu3/dlss_vs_fsr_in_edge_of_eternity_what_a/
I know most not... but some... so FSR 1.5 - 2.0 might bring more quality, same as DLSS 2.0 did. Also FSR 1.0 still very early right? so who knows, with good optimization perhaps it can be pretty good, even before next version comes.
Howardohyea
Proper
May 13, 2021
199
45
120
DLSS 1.0 is pretty poop performance/image wise, plus it requires tons of computational power to process it first before being available for implementation
Fiorezy
Notable
Jul 3, 2020
378
85
840
24
As I mentioned in your other post, Nvidia's RT and DLSS are more matured than AMD's counterpart. Don't bother yourself with comparisons and enjoy your card while you can.
