Hey everyone,
Here is a screenshot from intel's extreme tuning utility showing the fluctuation. This is using the stress test and at 100 percent CPU load.
It's relatively hot in my apartment and my package temp is idling at around 38 C and will sometimes jump up by 10-15 degrees but the fluctuation is much more clear when under load. Those peak differences are about 15-20 C. The max peak was 73 C. The lower points are about 52 C. Core temp shows fluctuation like this between readings as well.
As you may see I'm running a slight overclock but if anything I have turned down the voltage from stock. Using auto voltage on my Maximum Ranger VIII, the voltage would also fluctuate and sometimes get up to 1.45 which I thought was quite high for stock so now that is more stable but still the varying temps.
I have tried reseating my Hyper 212 EVO with new paste application and may have lost 2C.
That's all the info I can think of. I guess I'm wondering if (and hoping that) this is normal/acceptable? I haven't had any crashing while gaming or stress testing so far.
What do you all think?
Thank you
Thank you
