G
Guest
Guest
I'm just needing other peoples opinions on if these temps, multipliers and voltages all check out.
I'm able to get my 6700k with the Corsair H115i AIO up to 4.5GHz with 1.3-1.305v (crashed once somehow at 1.3 so bumped a bit just in case) and see temps go up to about 77c with this cooler and 64c on a chilly day.
but just going up to 4.6GHz with 3.5-3.505v (once again, didn't crash on 3.5 but went up once again to be safe) and I get up to 85c with a randomly jump to 88 for a second.
4.7GHz almost instantly blue screens at 1.4v and the temps I imagine would be way too much.
Do you think these temperatures are normal? I opted to replace the stock fans on the cooler for some Industrial Noctua 2000rpm fans too (not because of this, when I first got it). The ambient temperature is around 20-25c when I test these besides that one chilly day.
I've reapplied thermal paste the the cpu numerous times (Noctua NT-H1) and that seems fine.
I moved my radiator to the front of my case as I have a open fan style GPU which caused an additional 10-20 degree increase. (If you're skeptical about that, here's a link to a video explaining it in detail: https://www.youtube.com/watch?v=xNAMxZgvves)
Are these temps normal? Is my cooler doing it's job? Are the voltages alright?
I have tried researching this but it's so riddled with random voltages, random multipliers and random coolers I couldn't figure it out.
Thanks!
EDIT: I also forgot to mention that I use a maximum on 75% on my fans to reduce noise.
Thanks!
