So I have 4 Options here with my problem. I'm trying to solve it.
I have 3 PSUs I can use ATM. (All pretty much such)
so PSU 1) 450 Watt 22A +12V Rail.
2) 200 Watt PSU +12V 10A
3) 180 Watt PSU +12V 17A
CPU-ID HWMonitor says the power draw is 176.0 Watts. I don't know if thats correct so I would like someone to verify that for me....
I am more than %100 I am going to buy a new PSU but thats in a few days and I want to test my card before to make sure its not DOA.
So here are my options from what I see:
1) Use the 450 Watt for the MOBO & GPU.
2) Use the 450 Watt for MOBO and 180 Watt for GPU
3) Use the 450 Watt for MOBO and 200 Watt for GPU
So which option should I go with.
PS: The 6-Pin converter I got with the card only uses 1 4-Pin Mollex.
My card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102941
My rig: 4 Sticks of DDR3 1333 (2x 2GB & 2 x 1 GB)
AMD Phenom X4 B55
1 5.4k RPM 2.5'' HDD
2 Case fans ( 120mm?)
1 COMBO Drive (PATA)
1 PCI-E NIC
AMD Phenom X4 B55
1 PCI-E NIC
