Hello,
Last week ive put together my new system, here are some specs;
6850K 1.26V 4.3gHz
Geforce GTX 1080 FE SLI (overclocked +190 to core, +250 memory)
ASUS X99 Strix gaming motherboard
Phanteks Enthoo evolv ATX tempered glass
Full custom EKWB cooling loop with D5 pump running max
Here is the issue: I have a 240 slim rad up top as exhaust and a PE360 rad as intake both in push config. With this cooling setup i thought i would get decent temps. The system idles around 30C but when i play a game like Crysis 3 the cpu reaches 75C and the graphic cards around 70C. All my fans are running around 1300RPM cause i like a quiet system. But still i thought the temps would be better. I've removed the front panel of the case to increase airflow and that helps a bit but its not a long term solution.
Do i not have enough radiator space? Should i try a push pull config? any ideas are welcome.
Thank you
6850K 1.26V 4.3gHz
Thank you
