I have a Powercolor 6950 reference 2GB card that I flashed to a 6970.
I've been running the fan manually set at 45%, and I'm noticing it makes random loud noises now...almost like a vibrating noise.
I'm also not very happy with the noise at that setting, but I like the low-ish temps.
Anyways, is there an aftermarket solution made for the 6950? Or am I gonna have to look for older ones that might fit?
Link would help largely
Also if there's any guides that help me install would be super nice.
Thanks!
I tried searching for guides but I couldn't find anything.
I need a tutor for google.
Thanks!
