6GB RAM installed (1.45GB usable) - help
FinlandBlue
6
Just for a new laptop PC. It indictaes "6GB RAM installed (1.45GB usable)" - how can it be only using 1.45GB? Is there something I can do to change this?
Its a 64 bit version of Windows.
Thanks for any advice.
On Task Manager-Performance-Memory it says:
Memory 6.0 GB DDR3 Memory usage 1.4 GB
In Use 1.1 GB
Avaialble 299 MB
Committed 1.8/4.4 GB Cached 302 MB
Page Pool 141 MB Non-paged pool 62.1 MB
Hardware Reserved 4.6 GB
from other forums, other people have suggested a bios update helped them but its most likely a memory option in the bios but try the update and look for any memory related options on the lines off address space remapping etc and enabling it.
