No and no.I wanted to know is it okay to use 6pin to 8pin converter or molex to 8pin converter?
I have an PSU which has a extra 6 pin connector but I wanted to buy another motherboard which requires a 8 pin connector, so I wanted to should I use converter?No and no.
Adapters are almost never a good idea. If the PSU does not have the required connections and available power, you need a new PSU.
What are you trying to power, and with what power supply?
Details, please.I have an PSU which has a extra 6 pin connector but I wanted to buy another motherboard which requires a 8 pin connector, so I wanted to should I use converter?
I accidently posted it on Storage section, though I taped on motherboard section😑Storage devices don't need either of them. I'm saying that since the thread has been posted in the Storage section. Also, if you're trying to use an adapter to power a device, your PSU is very likely not fit for the job.
I was planning to buyDetails, please.
Make/model of everything.
"everything" includes the power supply in question.I was planning to buy
Ryzen 5 3400g
Mobo gigabyte b450 m h
8x2 3200 ram
Yes, I have an old 500 psu, So that's why I wanted to know should I get a new psu? Or should I use old one"everything" includes the power supply in question.
Yes, you need a new PSU.Yes, I have an old 500 psu, So that's why I wanted to know should I get a new psu.
