Hi all,
I just bought the HyperX Cloud 2 which come with a USB Virtual 7.1 surround. My Motherboard is the Z97 Extreme4 which has a 7.1 sound integrated.
I use the headphones for gaming. What is the 'best' way to use the headphones and the 7.1 surround? Plug them straight to the motherboard or use the HyperX's USB 7.1 dongle?
Also for most games you can select the type of output you have so 2, Headphones, 5.1, 7.1 etc.. What should I select when I use the 7.1 dongle or the motherboard?
My questions are:
1. Should I plug straight to my mobo or use the 7.1 dongle?
2. Should I put the setting under 7.1 or Headphones in the games menu?
thanks!
My questions are:
thanks!
