+70 fps with 144hz monitor but feels like 30fps.
encise
Commendable
Aug 21, 2018
115
Hello, before 5 days maybe i opened a thread about this thing, but the guy told me that lag because u have 3gb v-ram on ur graphics card, today when the open beta of black ops 4 came out, i tried it with low settings and i was gettings 60-80fps with a huge lag, its feels like 20-35fps, Idk what's the problem, today i just saw a video testing BO4 Blackout on GTX 1060 3gb wich is the same as mine, and he got on medium +70fps and his screen feels so smooth not like me, and he also got i5-7400 , and i have i7-8700k overclocked to 5ghz!!!!, so i should get around 80 fps, but atm im getting 60-70 fps and the game feels so laggy its just feels like 30fps not smooth like him, my specs
gtx 1060 3gb
i7-8700k ( 5ghz )
16 gb ram ( 2133mhz + 2400mhz ) dual channels
My screen " BenQ XL2411 144hz " ( DVI-D ) Cable .
i will be so happy if someone fixed my problem, and i will donate him also because i tried to fix that for along time ( more than 3 monhts ).
This is the video if someone want it: https://www.youtube.com/watch?v=G2HAlVO1hHM
Thank you.
I suspect the mixture of RAM isn't helping the system's performance.
Plus not getting 144+fps for a monitor with that refresh rate would likely be something which affects the experience. Does enabling v-sync or similar help to smooth out the experience?
I'm sure others will have ideas.
V-sync will not help, it will gave him huge input lag even if it's smooth
MERGED QUESTION
Question from encise : "1080ti + i7-8700k, +100fps but the game feels laggy"
Is it possible to try a different monitor?
I tried but 60hz, and same problem, and btw i bought 1080ti 11gb aorus, and i still have the problem .
Yes i tried to reset my pc to a fresh and still, maybe its from the game, hold on i will try BF1 when its finish downloading
by any chance do you have....
1) a secondary monitor that is lower refresh rate than your gamin one
2) how are your thermals (bo4 was very cpu demanding)
3) whens the last time you cleaned / maintained / changed thermal compound
its hard to kinda test this out now since the game isnt out unfortunately.
also are you having same issues with other games?
I just bought a 1080 TI Aorus, and i last time i changed the thermal 1 month ago~ or less
And when i was having the issue i was using 1 monitor only, now i use 2, i didn't tried BO4 because its not out
And the open beta is off atm, i have this issue so hard with Fortnite, in ultra settings i get 100fps+ but the game feels laggy and stuttering, i thought the problem might be with the 3gb but its not, because my 1080 ti now is 11gb, anyways i have different rams ( Hyperx 2133mhz + Hyperx 2400mhz ) Does that make an effect? or maybe the problem because my rams.?
