720P with higher settings VS 1080P with lower settings
QuadRings
424
Basically, do I want the slight fuzziness caused by 720P or lower textures on 1080P? Is there different resolutions I should use for specific games (See Bottom)? And should I go with Vista 64 SP2 or Lubuntu?
Specs:
Core 2 E6700 @3.3-3.6 GHz
750Ti @ Stock
x2 2GB RAM DDR2 @667MHz
7200RPM HDD
5400RPM HDD
Vista 64-bit SP2 or Lubuntu 64-bit (w/ WINE) whatever runs things better
Modified eMachines T5224 Case
Games:
ATS
ETS2
OMSI 2
FSX
Gmod
Minecraft
SPiNTiRES
War Thunder
XBox One Game Streaming
That's kind of a personal decision. Myself, I would opt for the higher in-game settings at 720p over low settings at 1080p. But if your monitor is native 1080p, it may be best to stay with 1080p. On a native 720p display, the games will look very good. The image quality loses a bit when a 1080p display has to run in 720p mode, tho.
