750 Ti VRam problems
VillAl
27
Hi.
I recently bought a used 750 ti from internet, its an Asus OC edition, it should have 4gb.
But it only shows 1gb.
Can i fix it or did i got ripped off?
atljsf
BANNED
the second more than the first more likely
what exact model?
i can't find any 4 gb asus gx750 ti
i do find this one
https://www.asus.com/Graphics-Cards/GTX750PHOC1GD5/
is the same you got?
it is not a gtx 750 ti, is just a gtx 750 with 1 gb of vram
VillAl
27
atljsf
BANNED
looks like this one
https://www.asus.com/Graphics-Cards/GTX750TIOC2GD5/
but i dont see a 1 gb nor a 4 gb model, perhaps is defective?
if you can return it or use any buyers protection plan on the site you used to buy it, that would be great
VillAl
27
VillAl
27
I got a replie from the seller, he confirmed me that its a 750ti 1gb, i misread it and thought it was a 4gb version.
I can play everygame i want (even gtav in medium/1080p/40fps).
I'm happy with this gpu, i'll have it unitl VEGA is out (if they have a nice price).
Thank you for your time :)
atljsf
BANNED
those are great news, i never seen a gpu detecting half of the ram it should have, i have seen reporting 8 megabytes or something like that
the fans and the ram amount tells me it is not a common model, that is why it got me so confused
