750TI For My Mobo And CPU
kingkobe21
Commendable
Dec 19, 2017
63
So i'm planning to buy a gtx 750ti will and i'm not sure if my motherboard will work on it's an INTEL H57 Mobo and the gpu im replacing is the gt 320 my cpu right now is i5-650 will this work?
So I was looking at my motherboard's specs it has 1x,2x,4x pcie configurations and when i look it the mobo from your link it has x16 is this a big difference on gpu compatibility?
So the 750ti would work? And if there are other better gpus could you state some?
and would this work with my i5 650?
If this means getting a new psu i'd be down doing it
https://pcx.com.ph/product/fsp-hexa-he450-450watts-power-supply/
would this be ok? i could probably get a gtx 970 and just start upgrading my parts from there not all at once though would my cpu bottleneck my the 970?
