avtechq07 :but nvidia partners like asus,zotac,evga provides a 6 pin power connector
Yes They Use 6 pin power connector only for Over Clocking Version And Super Clocking Version in GTX 750 and GTX 750 ti Chipset
Not For Normal Version
I have MSI OC 750TiThe 6pin version might have slightly higher stock clocks, but I would need to know which 750 ti you are talking about to be sure of that. It also might overclock a bit better.
I have MSI OC 750Ti
But it has not any pin connector . Just pci slot. .Yes that 750ti is one of the faster ones. As far as 750ti cards go, it's a good one.
Thanks. . Good. . I have already this card. . Thanks for help . .1 basic thing that make mr happy is has not any noise . Great . .😁Okay I have done some research for you and have found that it doesn't really matter whether it has a 6 pin connector or not. The 750ti cards with 6 pin connector can allow higher overclocks. But all 750ti models are close in performance anyway. Your MSI 750ti OC is amongst one of the best 750ti cards according to my searches.
So, if you already have that card you should be happy and not worry. I hope I answered your question
